IFO EDIT WONT CREAT IFO`S ON MY MERGED VOB IT SAYS
"could not find any VOB unit in VOB file(s) "
what does this mean ?
Results 1 to 17 of 17
Try renaming your merged VOB's in this format:
VTS_01_01.VOB
VTS_01_02.VOB
VTS_01_03.VOB
VTS_01_04.VOB
...and so on (up to VTS_01_09.VOB max).
Then click "create IFOs" then select VTS_01_01.VOB, hit open, then OK. -
it might have something to do with your vob file being larger than 1024mb so it won't be recognized as a valid dvd
Get Vstrip from:
http://www.digital-digest.com/dvd/downloads/vstrip.html
It will split the 2GB VOB to two 1024MB VOB's without rerendering. It's very fast & easy.
or......
Chopper XP from:
http://www.digital-miner.com/
It works very well too. -
Move your VOB to an empty directory, then rename it to VTS_01_1.VOB, then use IFOedit to create your IFOs.
I don't know much about the DVD spec, but all DVDs I read the largest VOB is 1 GB, this maybe a problem.
You can try importing your VOB into DVDlab, do not demux it, then create menus/chapters/whatever and the resulting DVD will have VOBs less than 1GB each. -
Ok then....
Run Chopper XP-
From the "Options" menu... choose "Alternate time detetction" & "Clear marked positions on file open"
From the "File" menu... choose "Open" select the VOB you want to split.
You should see the total time of the clip in the lower right hand corner- right over the "Mark out" button.
I found you need to play the video for a second then hit "stop" before the "Mark in" button will work.
After you open the Vob file using the menu, play the video and then use the mark in and mark out buttons to set the start and end positions from which to extract the vob file. In your case- after you set the "mark in" point, simply drag the slider to the halfway point of the clip. When it's in the center, hit the "Mark out" button.
After you set the mark in and mark out positions, click Save vob from the file menu.Save the first section as VTS_01_1.VOB (save it in a different directory so as to not overight your original clip). Now, With the slider still in the "mark out" position, hit the "Mark in" button, then drag the slider to the end of the clip and hit the "mark out" button.
Click Save vob from the file menu. Save the second section as VTS_01_2.VOB
You should now have two VOB's of 1024MB or less each.
Run them through IfoEdit, select "Create IFOs", open the new VTS_01_1.VOB, hit "Ok" and let IfoEdit do it's thing. When It's done you should have:
VTS_01_1.VOB
VTS_01_2.VOB
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01_0.IFO
At this point you should be good to go! Give it a shot....... -
Unable to download an appropriate decompressor.
GOT THAT WHEN I OPENED THE VOB -
i just had an idea i have the 3 vobs with the ifo`s and the bups can i not just put all 3 vobs in the one folder use the one set of ifo`s and bubs ,rename the vobs to VTS_01_001,VTS_01_002,VTS_01_003 wld it not work ?
i merged 3 svcd`s into ` vob file but it is 2 to big to create ifo`s and buo`s for it has it is 2gb.It would be good if someone wrote a guide that actually worked for this
stevo
use isobuster (freeware on this forum) to stip your svcds into 3 seperate mpeg files
use any video editing software(i.e. neodvd ,video sudio 6, pinnacle studio 8 , etc) convert the movie to dvd
or use the program that u use to convert your svcds to vob, but don't convert them to one large file, convert them to 2 files and then u can use ifoedit
Can I create an .IFO file from .VOB files?
By Madcap in forum DVD RippingReplies: 7Last Post: 15th Aug 2010, 14:57 -
How do I create VIDEO_TS IFO from VOB files
By stockton209 in forum DVD RippingReplies: 2Last Post: 8th Jan 2010, 03:07 -
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 16:54 -
Create IFO from VOB w/o IFOEDIT?
By theschles in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 18:19 -
how do i create ifo etc files
By gurunutkins in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2007, 11:41
